Tiller outboard won?t stay straight
I have a 1974 Evinrude 15hp tiller outboard on a 14? open boat. When I get up on plane, if I let go of the control the outboard makes a sharp right turn. I?d like to be able to let go for a minute without that happening.
Is this because the outboard isn?t centered on the boat? I think that it?s centered.
Is there any way to tighten the steering to make it harder to turn and stay straight? DSL07016GS
Tim Frank
Re: Tiller outboard won?t stay straight
Three things can help:
1) Boat trim....make sure boat is level side to side.
2) There is a trim tab (on most models) just behind the prop. It can be adjusted to fine-tune steering pull.
3) There should be a friction adjusting screw...on that motor i think on the port side of motor, on the pivot shaft. Tighten or loosen as appropriate.
masintenn
I hope you have a dead man switch.
