TippyCanoe
- Jun 2, 2002
- 7
I have a 1988 Mercury 25hp with a tiller handle. When I am in gear and accelerate, the tiller handle use to have a tension in it so that it would spring back to idle when I released the handle. Now, however, there is no tension in the tiller handle and when I release the handle the motor will run at the same pace.<br /><br />I have checked the linkages and they seem to be fine. I can push on the main cam linkage, and this will move the tiller handle back to idle (I do this with the motor not running), but it will not return on its own. <br /><br />Does anyone know if this problem could be caused by something in the tiller handle (which I have not yet disassembled)? Or can the problem be somewhere else?
