Tiller handle crack behind throttle twist grip
oday25
I run a 9.9 on my sailboat. It seems when I tilted the motor up I may have cracked the tiller arm, right behind the throttle twist. Is this part replaceable or repairable? I have some marine adhesive curing on it at the moment and will check it tomorrow. Any ideas? Thanks....
tashasdaddy
Re: Tiller handle crack behind throttle twist grip
welcome to iboats, year and model # of motor, please. mosly likely it can be replaced.
wbeaton
It is certainly replaceable. It can be repaired by welding. If its not too bad then drill a small hole on either end of the crack to stop it from spreading and don't worry about it. If its really bad, don't trust epoxy to fix it. It will probably fail and that could have catastrophic results.
Lodgepole
I got a real nice used replacement for a 25 that got burned off from Tim's Outboard. Reasonable! 218 682 2331
oday25
1997 saildrive, JSELECC I think is the model number. Found a source for parts, $55.00 for what they called a Steering Arm. The guy said it isn't hard to replace as long as I have a photographic memory...hmmmmm.
Thanks for the quick reply
oday25
Thank you...I did find a replacement part. Once it arrives I'll try it out.
oday25
The crack has traveled all the way, and I have removed 90% of the arm. Easy enough. How do I remove the throttle grip assembly off of the remaining steering arm?
Great site; thanks all.
steelespike
I answered your other post.
