Re: Tie down strap question
I guess you love 'em or hate 'em. I love mine. It does take a while to learn how snug to have the strap before you flip the handle, and you do need to remember to keep your fingers out of the way when that handle snaps over. I run the extra strap up between the handle and the strap, then back over the outside of the handle, then thread it through the slot at the bottom of the handle. I then fold the strap over and over until I have it all 'rolled' up, then lay it along the handle on the inside and enclose it with the velcro flap. The strap might loosen if the boat settles, but I don't worry about it unless there's so much slack that that a lower hook might come out.<br /><br />The reason I prefer the handle type is that it's simple and reliable. On the way home from the ocean, I'll stop by the lake and back my rig in the fresh water to flush the motor. I leave the boat strapped on the trailer. (While I'm running the motor, the fresh water comes in the open transom drain to rinse the bilge; a great check to make sure the bilge pump switch is working.) The trailer gets backed in and out several times after the motor flush for it's 'rinse'. It's been my experience that the ratchet type doesn't hold up well with this kind of treatment. YMMV.
