Benz Mondi
- Aug 30, 2010
- 125
Just thought I'd give those considering this product a heads up. I read the reviews both on this site and at BassProShops and not one mentioned that these are actually full length PVC covers that are a substitute for the bunk carpet, not for the whole bunk itself. They are installed over existing bunk lumber. Accordingly, in replacing rotten bunks, you'll have to factor the cost of replacment lumber along with the cost of these covers.
I just got these delivered and was obviously suprised. That having been said, they do appear to be well designed and built. They come in four (4) 50" lengths that cover 2" x 4" lumber and have 1/4" x 1/2" angled ridges that are meant to help guide the boat toward the middle. You have to make sure to install them properly. The ends have a curved cap so that there are no exposed, blunt ends. They are attached at reinforced spots along the sides via the supplied stainless steel, self-tapping screws. There is no hardware attachment at the top surface to endanger the boat bottom. This means that you have to make sure that the cover lies completely flat against the top surface of the bunk lumber or the compression of the boat against the gap will eventually cause the sides to crack at the screw points. Turning the bunk lumber over with the cover at the bottom and stepping on them while the sides are screwed in should do the trick.
For my trailer, I only need 7' bunks so I'll have to cut an equivalent amount off of the butting ends so that I maintain the proper groove alignment. Now to get some pressure treated 2 x 4's at the home center.
Al
Al
