Thunderbolt V timing
hello
i have replaced the 5.0 in my boat with a 5.7 i wanted to use the wire harness that came with the 5.0 and the thunderbolt V system. last year the when i installed it the icm wouldn?t advance as the rpms rise. I decided without trouble shooting it to replace the ignition with an aftermarket msd distributor. boat ran great until the last trip of the year when the ignition failed. I sent it back and they confirmed that it was bad and they rebuilt it. this year I tried the thunder bolt V again. it appears to advance but not as much as the advance curve graft from mercruiser. The boat runs good but dogs upon a hard acceleration
so my questions are without a load on the motor will the distributor-* advance as showed in the graph and is there any way to test the icm I?m also wondering if the icm for the 5.0 work with the 5.7
Ayuh,.... Welcome Aboard,...... That sounds like fuel delivery,.... Induction,....
Is this carbed,..?? Efi,..?? Mpi,..??
The 350 should run fine with the 5.0l module,...
alldodge
I need more info
What MSD distributor did you use (part or model number, something)?
What model TBV do you have?
What base timing are you setting the motor at?
the 350 has a quadrajet on it and the 305 had a 2 barrel . the [h=1]MSD Ignition Distributor, Chevy V8 Marine, Ready to Run[/h]
Part No. 83606
had to be set up with the lightest springs for the quickest advance and it worked great last year
the tbV from the 305 is a 861459-1 and i have a used 861254-1 im going to try next .
i just not sure if without a load on the motor will it advance like the graph of the advance curve
ive got the base timing set at 10 degrees before top dead center
alldodge
Sorry, but all I'm getting out of info requested is: the thing a magig was over there and was set by Billy Bob
The one thing that has info is the ECM does not have a knock module
CaptainMak
So you have an advancing timing light and know how to use it I presume? The CARB models are 10? BTDC. Is it ? If not, you'll have to follow a procedure to set it correctly. You can't just do it in idle.
Then go from there. Take measurements at 1500rpm, 2000rpm, 2500rpm and follow the graph you posted. It should be advancing close to the chart. BTW, at over 2k RPM, you'd probably want the boat in the water, not on a hose.
i dont have a advance timing light
i have been watching the timing while someone works the controls
if you rev it to 1500rpms it will go to 18 the fall off to 15
im thinking it could be the MBT mode adjusting the timing
the graft shows advance of 15 +the base timing
alldodge
The TBV has to be put in base timing mode to set. If you have a MSD box, I don't know. To put in base timing for TBV you ground the Purple/White wire and the set timing
achris
More fish than mountain goat
Part No. 83606
You can't use a TB-V (or IV for that matter) with a distributor that has advance weights and springs. Pick one, TB-V OR weights and springs.... Not both.
CaptainMak
Are there any active codes that you're aware of ? That's when an ECU might throw itself into a derate mode.
Can you give us the readings at various RPM's ?
