thunder bolt ignition system
ez4u
no spark to plugs. changed pick up module in distributer, amplifier module, rotor. cap is good and coil gas twelve volts.it is a 1987 merc 350hp cruiser two barrel merc carbrator. have 12 volts to coil 12volts to red-white wire to pick up module what else could it be? is there something im not seeing?
Trent
Re: thunder bolt ignition system
xhgpilot
Could be the shift interupter switch shorted to ground or wired improperly.
