Thrust Washer Question
wil7483
I seem to have lost the thrust washer off of my stern drive. Can someone give me the correct part number to help me find a new replacement one. It is an Alpha One drive approximately 1984 circa.
picklenjim
Re: Thrust Washer Question
What thrust washer are you talking about?Need more information than that.
Gary H NC
Any Mercruiser dealer could fix you up....
I know some gear cases use different thickness thrust washers but the dealer could look at the prop and shaft and find what you need.
wil7483
The one that goes on before the prop.
Bt Doctur
Assuming you mean the one behind the prop
835467 W/ Blackmax props
56292A4 W/ Mercruiser props
Ayuh,... There are several,... You need the 1 that matches the Prop...
And,...
Some props don't use a thrust waher, it's built into it...
