thrust hub
jpbrown3
is it common for the thrust hub not to come out of the prop hub when taking off propeller?
i am looking in the manual and its telling me to put the thrust hub back into propeller hub when putting on the prop.....
im looking a the prop where the hub is and its jammed in there.....i think that is what im looking at....
WillyBWright
Re: thrust hub
It happens, but they rarely stick hard. There are a lot of configurations. They can differ between motor brands and prop brands. Wutcha got?
Re: thrust hub
Ayuh,........
And Some props have the Thrust Hub Built right Into the Prop.........
jpbrown3
Re: thrust hub
i have a mercruiser prop for an alpha one
im looking at it right now and it looks like it is impossible to take that out? hopefully this is the one that they are built in because i painted it while it was on.....
pic is attached....
Texasmark
Re: thrust hub
That looks like what we used for 10's of years before the new plastic hubs a lot of folks use nowadays in their props.....rubber slip hub that is pressed in and no, it stays with the prop when you take her off....need a press to get it out.....and no reason to.
Mark
kp913
Re: thrust hub
Right, that is not the thrust hub (washer) that is just the bottom of the rubber hub. The thrust washer for that may still be on the shaft of the lower unit.
propellerforumdotcom
