Thru Prop to Thru Hull Exhaust swap ???
sinfuse
i have a 21' baja with a 350 merc and alpha I drive.. the exhaust is currently thru the prop.. any ideas on price, where to get parts, kits, installation problems ect... i want to change to a thru hull design with stainless tips !! Oh by the way, im looking for a used trailer for the boat anyone got one for sale??
Capt Ron
Re: Thru Prop to Thru Hull Exhaust swap ???
If you decide to go with a thru hull exhaust set-up then the original M/C exhaust should be vented. This can be done by attaching a hose to the exhaust outlet port inside the boat and extending it above the waterline as much as possible. This allows air to be drawn through the prop to reduce cavitation.<br /><br />Capt Ron
