SeattleMatt
- Jun 22, 2004
- 237
So I have a project where I have replaced the gimbal housing on a 1996 Bravo I, the replacement gimbal housing came with a plastic through transom water pipe, whereas the old transom had the standard 3/4 water hose with the tapered insert on both ends of it, and I housing with the hose Outlet to connect to the existing 1 1/4 water hose which goes to the engine mounted impeller. The problem is the new design with the plastic pipe is too small for the larger water hose so I need to step down to that size for it to fit on the plastic pipe. Am I doing this wrong? Should I just get another piece of hose and put a hose clamp around both layers to make the size? Or is there some other method that is in the design?
