MJS
- Jun 4, 2009
- 124
I have a 94 Evinrude 25 that has ran fine until I took it out yesterday. On the previous trip I ran the gas tank empty on accident but filled up and kept going fine. Yesterday I got about a mile from the ramp and it's puttered and died. I could start back up and had a slightly rough idle but would die as soon as the throttle was applied. It took a long time to idle back to the ramp and the engine would run for a few minutes then die and run for a few and die and run for a few and die... Today I messed with it for a bit on the water muffs and discovered that it dies unless you use your hand to cover the air intake a little. It reves up fine when the air is restricted which makes me think its not trash in the jets or something. Any help is appreciated.
