Throttle switch 95 Mercury 150 outboard
? where is the interlock switch and how can it be replaced. This is on a 1995 Procraft Bass Boat. 1995 150 Mercury engine.
WillyBWright
Re: Throttle switch 95 Mercury 150 outboard
Chances are it's in the remote control. If it's a surface mount box, then you have to remove it and take the back cover off to get to it. If it's flush mounted, then you have to take the handle off and remove the box that's behind the wall. It's inside that box. In either case, look for yellow wires with a red stripe.
