lhutrack165
- Mar 13, 2012
- 12
So I bought a boat last summer and for having a 1989 85 hp Force it ran well with no major issues. Occasionally the throttle cable would freeze up and not go wide open but once it was used it would work free and be completely fine. After getting it out this winter It was stuck again and would not work loose, it does go into gear tho so I just thought the throttle cable was bad. So I unhooked it from the motor and when I worked the controls the stiffness was gone, controls would go to wide open and the cable seemed fine. So I thought it must be the throttle body that was sticking. But when I checked it I could move the throttle fairly easy from closed to wide open and back. So my question is, is it possible for the cable to be bad and only show up when under stress?? I don't what is causing the stiffness when individually everything seems normal. Help Please!!! Thank you!!
