Throttle removal
scottsbws
I have a 97 sea rayder f16. I removed the 4 screws holding the throttle to the fiberglass but can't pull the unit out of the boat. Cables are attached and are too far to reach from engine compartment. HELP!
steelespike
Re: Throttle removal
This probably needs to be in boats only or the I/O section.
Can't be too helpful but when you do pull it out fasten something to it so you can guide/pull the new back in.
Speaking generically you may be able to remove the cables from the control
and push them toward the engine compartment.
