I posted this in the engine forum, but not sure that was the right place, so I'm cross posting it here. Please forgive me if this is a problem
Please forgive me if this is not the right forum, but I didn't see one that fit much better (except perhaps the Wellcraft forum).
Anyway, I need a replacement throttle control (I believe its called a remote control??). Its a 1988 Wellcraft 220 and I don't know the part number. Would this be in the repair manual for the engine or perhaps the drive or some other manual? I've attached a picture with some items marked that I needed some additional input on.
Bear with me: (A-E are marked in the picture)
A = "bar" that slides in and out to allow throttle movement
B = Button to engage prop/drive
C = Brass bar from D to A
D = Top of throttle with push lever
E = Screws to adjust throttle friction and stiffness
The top of the throttle (D) is broken. I have taken it apart and verified that a piece of the plastic is cracked. (I would have posted the picture, but couldn't figure out how to get the size small enough).
Throttle Image
Questions/Comments:
1.) Apparently the "C" brass bar is supposed to move when you push the lever on the throttle and move the "A" bar to allow throttle movement. I can't see how this is supposed to work though (perhaps only because D is broken).
2.) How do I get "B" off/unscrewed??
3.) Apparently this throttle has been replaced because the screws in E are missing and actually aren't aligned correctly anyway.
4.) Where do I find the repair details and part number for this assembly? In the engine repair manual, the drive manual or some other manual? Its a quicksilver throttle assembly with the Trim swith and Trailer button to raise the drive up for trailering.
Any and all help is greatly appreciated! Please direct me to the correct forum if this is not the correct one.
Thanks again!
Chris
Throttle Image
Questions/Comments:
Thanks again!
Chris
