Throttle linkage for 40E 676BL 412042
RealDad6
I have a 40E with serial number 676BL 412042. The best I can tell this is a 1979 model. The throttle linkage inside the case was disconnected when I got the boat and motor. Can anyone tell me where to find the diagram for the linkage connections and a possible source to get the parts that are missing? And confirm that this is in fact a 1979?
RealDad6
No Title
Fun Times
Using the serial number, The model number found (7040522) has your year to be an 1982 while the charts found online for your serial number ends it with 1981. The L = Long Shaft...
40 EL
676B-410851 -
1981
Here's should be your parts diagram through iboats for you,
http://www.iboats.com/MARINER-40A-EL...iew_id.1697257
And here's your throttle linkage diagram a well, http://www.iboats.com/Throttle-Contr...iew_id.1697247
Upon further thoughts, do you know if you have the Above Exhaust system or Through Prop Exhaust as there's separate parts listings for each system ?.
