Throttle lever tension adjustment? how? 1997 twin Merc 115
adobe wall
Okay I've got a pair of 1997 115 Mercury outboards. The throttle/shift cables were replaced right before I bought the boat (August 2010) and the tension doesn't seem correct.
Should the levers stay where they are when I take my hand off the levers, or should they ease back to idle? Currently if I take my hand off the throttle, the levers slowly back down to idle. Makes running a long ways more work. If that's a "feature", not a "defect", let me know and I'll stop complaining. Otherwise does anyone know how to adjust the tension? These appear to be Mercury remote throttle levers, I have easy access to the underside of the dash but see no obvious tension adjustment. Any help appreciated, I can also get pics if that's necessary.
thanks,
aw
pinellas50
Re: Throttle lever tension adjustment? how? 1997 twin Merc 115
Another thing we have in common. Mine will slowly ease off as well if I take my hand off. I have yet to find a tension adjustment.
Note--- you probably already know but it is a safe practice to always have your hand on the throttle when under way. Just thought I'd say it before the soap boxes come out.
saumon
If you have the standard Mercury/Quicksilver side control, the tension is adjusted with the knob in front
