Throttle Cam Follower Replacement
rdgallo
Please excuse me if there is already info available on this forum for this. I did a search and could not find what I needed. I have a 1994 150 Johnson Fast Strike outboard that I need to replace the throttle cam roller. The model of the engine is J150 GLERV. I purchased a new cam roller (part number 323326) on line and now need to install it. Can any of you give me some information on how to install this correctly? My service manual does not provide much on this. Is this cam follower roller a press fit onto the throttle cam roller? This replacement cam follower is black and has a recessed (circular grooved) area on one end and is smooth (flat) on the other end. Does the grooved end assemble up or down. Any help you can provide will be greatly appreciated. Also, is part number, 323326, the correct replacement follower for this engine?
Thanks for any help.
rdgallo
Re: Throttle Cam Follower Replacement
Surely one of you has replaced one of these on 1994 johnson or evinrude? LOL.
