throttle cable
freeskimon
As mention in my other post, I'm having problems with a stiff throttle cable. Dan suggest I replace it - good idea but where do I start to look for one. Plus do I have to get to the back side of my shifter to remove the assembly?
DHPMARINE
Re: throttle cable
Ya,you have to get to the backside of your shifter.Once you disconnect the cable,try the control again.This will let you know if the stiffness was the cable,or is in the control.If it's the cable,it will have some #'s on it that will help you ID it and order one.<br /><br />DHP
