Re: Throttle Cable adjustment
Did it ever work right to your knowledge? When you push the throttle/gear shift handle as far as it will go forward does is end up roughly horizontal? If not there may be something broken or misassembled in the control box. Someone may also have shortened the internal wire in the throttle cable or installed it incorrectly which would prevent full motion of the throttle. If the throttle cable is the problem you will need to replace it. If so, look closely for part number on cable near the motor end. If can't find it, then measure the cable and round up to the next foot. If the cable end have small allen set screws where it attaches to the the throttle arm in the control box or at the motor then the Teleflex number for it would be CC170xx, where the xx is the length of the cable in feet. This is most probably what you have. If no allen screws, then the part number is CC205xx. BTW, the price of these cables vary widely from 13 to 58 dollars for the same cable. So shop carefully. They are sold here on Iboats for around 20 dollars.
