Throttle Body Damage???????............see pics
wmacleod
I may have tightened the needle valve too much, is there supposed to be a slight hole for the needle through the bottom????? You can see added threads......not sure if this is normal???
tashasdaddy
Re: Throttle Body Damage???????
what motor. which jet??
wmacleod
1995 90 hp johnson ocean runner, the pictures should help......................it is the single s/s needle valve with the spring, just above the bottom right screw hole there is a little hole/indent
wmacleod
Re: Throttle Body Damage???????............see pics
i'm an idiot...................i figured it out.
Faztbullet
These idle adjustments are preset from factory. Hope you counted turns out!!!. If not, start at 5 1/2 turns out from a lite seat. Final adustment will take 2 people, 1 to drive and 1 to adjust. Idle around with engine trimmed level and adjust in 1/4 turns and wait to see result. If you have service manual follow it to the letter!!!
