So i was given this '88 Evinrude 48SPL, and i know little about it. I put the motor on my boat then brought it to the lake for a test run which i was assuming i would have to make some adjustments. While on the lake it didn't seem to have the power it should, so i put new plugs in, check fuel filter and lines and then the same things. I've noticed that there is a rod coming from the lever where the throttle cable connects and that rod runs to the carb and pushes the carb open further as you give it more throttle. On the carb side of the rod there is a screw adjustment that you can unscrew to make the rod longer therefor opening the carb further. I lengthen the rod and it seems to open the carb alot further than before. I just don't know if thats ok to do, i mean obviously that can adjust for a reason i just want to know if thats what i needed to do.
