Hi Folks, I just removed the regulator/rectifier assembly on my 1995 Johnson 130 and am looking for advice on a few things.
1. What type of gasket sealer would be OK to use on the regulator gasket? The manual says to use an OMC brand, but I am hoping some type that would be available at an automotive store would work as well. Any suggestions? I have thoroughly cleaned the gasket surface.
2. The bolts holding down the regulator appear to have had a green substance on them. Pehaps some kind of Loc-Tite? Would Blue Loc-tite be OK, or should I not use any?
3. The sound deadening foam inside the cowling looks like it is deteriorating. Do you recommend removing it? My fear is that the foam may become a continual source of carburetor fouling. Looks like real job to scrape it all off.
Thanks for any advice. Scott
