Re: three batteries, one for cranking, two wired in series for trolling m'tr
JohnKee, you're quite welcome, glad to help. <br />I checked the StealthCharger web site and it certainly appears to do what you need, that is, allow you to use 3 12v batteries, one for starting, 2 to provide 24v for the trolling motor, and the charging of all three simultaneously, a neat trick. There is one point of interest, the amount of charging current available for all 3 batteries and your drive engine's ignition, radio, lighting, and boat accessories is only what your drive engine's alternator can provide, otherwise you drain current from the starting battery, so for example, a 10 to 15 amp outboard alternator may or may not handle your operating boat system current draw much less charge the 3 batteries, there's no free lunch here. So, unless you run your boat engine long enough to recharge all 3 batteries you will need to supplement the charge with a shore based AC charger as noted on the StealthCharger web site. However, since it does what you want and automatically it looks like the cats meow.
