Thread size hydraulic hose VP SX drive
Wanna Tango
Does anyone know the size and thread of the end of the hydraulic hose that’s connected to the outdrive cylinders?
Volvo penta SX-M year 2000
TiA!
ESGWheel
As a follow up, if you are looking to clean up the threads in the aluminum cylinders or manifold block, suggest using a thread chaser vs. a bottom tap. A tap, unless started exactly following the existing threads will cut new threads and probably destroy the part. A chaser is as it sounds, will chase after the existing threads and clean them up in the process. Same process: lots of oil and back and forth.
Earlier this year when I had this issue Lou C recommended a chaser and was glad he did. Here is a picture of them side by side. And here is a post (link) about cleaning up these treads in a difficult place (manifold block) without removing the sterndrive.
Wanna Tango
Oh wow. Thanks for that information. I have the tap but I think it would be safer to use a Chaser. Will need to get one of those.
Thanks again for the follow up @ESGWheel.
