Still up in the air 82rude but thanks for asking. I only had one weekend to play with it myself and it was kind of a waste because we had friends up with us. I threw the 13 pitch prop (6000 rpm) on so I wouldn't lug the motor and just used it. Lots of fun even with the wrong prop on it. Although the 13 pitch was slower at 28, I couldn't get the boat to go slower than 25 even when pulling an adult on a tube. I was very pleased with the engine in every other way but the prop situation. We had some ups and downs and unexpected things go on as usually happens in life so we had to cancel a few planned trips up. I will be going up in a few weeks to close up and take the boat home for the winter. I'll play a little in the cold with a custom prop I had made but haven't been up to try. I'll keep you posted on one of my prop threads...or both lol.
Sod breaker, sorry for the highjack. I love most things about my boat which is more than probably the same hull. The construction is pretty rock solid. Take a look at my thread attached in my signature if you want to see the structure. The one knock I had about the boat was hopefully remedied by 87. All the wood in my boat, (which is a bow rider side consoles model) including the deck and console supports as well as the seat bases, was 5/8 particle board. As you can imagine, the particle board fell apart as soon as it got wet. The floor only lasted a few years (my dad bought the boat new). We installed a plywood deck when I was around 12. The expandable foam flotation was a joke too but alot of boats used it. I gained 5mph by just replacing the foam with new. There must have been a couple hundred pounds of water trapped inside the foam. We had a three piece bimini type top for years and it leaked alot so there was always water in the hull for the foam to soak up. I can't seem to find a pre made cover that fits well but I buy the 50 dollar cheapo silver job from WalleyWorld and it fits ok but only lasts a few years at best. It has been a great little boat through the years though and I would give Crestliners a thumbs up.
