thought about building my own boat?
i like my two boat right now but since my chrysler is done i need another project. i was thinking about building my own boat iv'e always wanted to build my own just never did. what should i do to build one? what size what type? was thinking about building a minitug i love those they look so cool. ideas please.
DuckHunterJon
Re: thought about building my own boat?
Go to Glen-L website and read up on boat building. They have several plans and kit's to build from. They also have a few galleries to look at others people have built. I built their Duck Boat Too from scratch (bought their plans and built my own frames). It was a ton of fun, took a bit over a year, but turned out great and I have used it the past 4 hunting seasons now. If you can tell from my avitar, it works great!
It's not a small undertaking, but very rewarding. My best advice would be to start out with a simple design, and learn the techniques involved in boat building. If you start with one too involved, chances are good you won't finish it. I started with the DBToo (12', flat bottom), and have already purchased the plans for the Honker (15', v bottom). PM me if you would like more info on my experience.
that sounds good and i was thinking maybe i could build them and maybe sell them later for some money
JoLin
Building one's own boat is really a labor of love. When you factor in the cost of materials and add in the umpteen hours it takes to build a one-off, it's doubtful you'd break even on the deal. Definitely a cool project to tackle for yourself, tho.
Have fun!
JimS123
My first boat was home-built when I was 18. It was the most rewarding challenge of my life and I'm a better boatman because of it.
Back then, there were several ways to do it. You could buy a set of full size plans and build from scratch with wood you got from the lumber yard. Secondly, they sold frame kits with all oak parts pre-cut. It came with the plans for the other parts. Finally, they sold full "kits" that came with all of the precut parts, screws, glue, paint, varnish, etc.
Not a task for the faint of heart. First of all, you need a dedicated building or garage to work in. You need a solid (and flat) concrete floor and a roof to keep out the elements. I wouldn't try doing it under a popup tent unless I lived in FL. Most of all, you ned a LOT of people to help at times. For example, laying in 18' long plywood bottom panels requires they be steamed. It took us 4 people to hold and screw the panels in, while 2 Grandmas ran back and forth to the stoves with kettles of hot water.
You should also plan on keeping the boat for life....LOL. Nobody wants a new wooden boat these days, so you'll never be able to sell it, and if you do, you won't recoup even half the money you spent.
As an alternate to wood, you could go ferro cement. But that's more geared to larger cruisers and sailboats. May need a bit more expertise, but they come out much more durable. Not many people around to get advice from though. Fiberglass is possible too, but you end up with a wood infrastructure anyway and that'll cost a bundle.
Glen-L is a good starting point. Also, Google Clark Craft.
i think i might start off with a jon boat but with a v in the bow. maybe about 8' long so i can just buy ply wood and 2x4 that way. i was thinking making the ribs out of 2x4 an then plywood on the outside and 2x4 on the top of that. then ply wood and 2x4 for the deck.
JimS123
You don't use twobafores to build a boat. Ribs are made out of solid oak. S-P-F will warp the first time you get it in the water, and then the boat will look kinda like a banana. Plywood needs to be marine grade, and all fasteners silicon bronze. Of course, everything should be glued together using a good marine grade resin glue.
Plans for a small boat like that don't cost very much, and they will give you a full list of materials.
Here's a bit bigger than 8', but you'll get the idea:
https://www.boatdesigns.com/11-Utility-utility_fishing-boat/products/371/
haley
I looked into this too. My favorite sites are:
Glen-l ( their Riviera is my dream boat)
Chesapeake Light Craft (clcboats.com) for kayaks, small sailboats, etc. I have their Skerry plans
And B and B yachts. They use newer methods than Glen-l and have a sweet looking center console.
You will have more fun, spend more money and take more time than you think. But life is good.
John
superbenk
You could check this out too. They're plywood boats & designed to be relatively quick, inexpensive & easy. I bought one of his books and am considering doing the Cartopper someday.
http://www.instantboats.com/
JimS123
Yup, books are great. If you go to the Glen-L site I referenced, they have literature you can buy that will lead you the right way. Even try the public Library. That's what I did! When I was 16 and decided I needed a boat, and couldn't afford, one so I became a voracious reader, consuming every publication I could get my hands on. My Grandpa was a carpenter, and between his woodworking skills and my boatbuilding knowledge acquired from books, we cranked out the family jewel in only 2 short years. Wasn't an internet back then to ask questions....LOL.
That was 43 years ago. I would still have her today for sure.....but sadly she was destroyed in an accident by a drunken driver 3 years after she was christened....
superbenk
That's a cool looking boat! Maybe it's time to build a replacement? :)
JimS123
The ole girl was a Luger kit, and they've been out of business quite some time.
As a matter of fact, 6 years ago I built a new garage / workshop with just that in mind. It was to be my retirement mancave. Since I don't have the help anymore, my intention was to restore an old classic. As luck would have it I found one! The bad part is that with my impatience I goterdone in less than a year, so my retirement project didn't last till retirement.
