This trailer has no suspenision!
b.gagnon
Master Chief Petty Officer
A friend of mine just bought a 05 18? angler cc?.It came with a nice looking aluminum trailer, but it has no suspension! Can this possibly be good for the hull? He will regularly be towing about 150 miles round trip for the bulk of his use once or twice per week.
Gary H NC
Re: This trailer has no suspenision!
Are you sure its not a torsion axle.They have no leaf springs but ride very well..
rndn
You can tell by adding some weight such as a person and watch to see if the torsion axle moves. You should see it rotate as the trailer is dropping.
wire2
Re: This trailer has no suspension!
Is the axle fastened directly to the trailer with U bolts? Or are there L arms from the spindle to the trailer?
jddenham
I have a mid to late sixtees trailer made by Johnson and it has no suspension.
kenmyfam
Show us a photo please.
jddenham
Here are some pics of my 1964 Johnson built trailer and it's lack of suspension. It came standard with a Johnson SeaSport gullwing style boat. Lots of funky rollers that I still need to remove.
PondTunes
A Torsion beam Suspension, also known as a torsion bar or torsion spring suspension, is a general term for any vehicle suspension that uses a torsion bar as its main weight bearing spring. One end of a long metal bar is attached firmly to the vehicle chassis; the opposite end terminates in a lever, mounted perpendicular to the bar, that is attached to a suspension arm, spindle or the axle. Vertical motion of the wheel causes the bar to twist around its axis and is resisted by the bar's torsion resistance. The effective spring rate of the bar is determined by its length, diameter and material.
Notice how the center of the wheel/hub is not in line with the axle tube, the center of the wheel/hub moves up and down twisting the torsion bar in the center of the tube.
