This supposed to leak ?
NewboaterMark
Hey i have a 1989 bayliner cierra sunbridge .. i didnt drain the block and cracked the block .. i put in new engine all is good but this hole leaking when running with muffs on .. is that supposed to happen ?? Thank you in advance!
alldodge
I hope your drive is up just because you can take a better pic.
Lets just say if the water was coming out of the lower ports then this is normal for a drive being on muffs.
There should be more water then that coming out, and also the drive should be down when running
achris
More fish than mountain goat
You also need to deal with these wires poking out. It also looks like someone :facepalm: has replace the sender and cut and spliced the wires... A big no no...
NewboaterMark
Ok thank you thank you for the help! And yes was just up for the picture! And when i put it in gear more water comes out .. and oh darnet ok i will get the wires fixed up! Thank you guys so much!
