Well I changed out the reg/rect yesterday, and I did not have to pull the flywheel. However, I did have to remove the power pack and the terminal block, which I found out could be removed after I already had all of the wires off.<br /><br />I also tried to trace down my fuel problem so I had the air cover off and I found a small hose (think it was the primer hose) for one of the carbs cut at both ends. I cut off the jagged edges and still had enough hose to re-connect it.<br /><br />So today I took it out and it would not come out of the hole, it ran at around 3700 RPM. After running for a little while it slowly got up to about 4900 RPM but nowhere near the normal 5800 RPM. I stopped and anchored and did a quick plug check, since I had the plug wires off yesterday. Removing the wire from each plug one at a time (starting and stopping the engine between times) seemed to drop the idle from 1200 RPM to around 600-700 RPM.<br /><br />So what happened, did I hook something up wrong, or does this sound like a fuel problem?<br /><br />Does anyone have the wiring specs for the ignition components? I think I hooked it up right (wrote it down while disconnecting) but maybe I mixed something up.<br /><br />BTW, the reg/rect did not fix my charging problem, just as the new fuel pump didn't fix my fuel starvation problem.<br /><br />I'm batting a thousand, please help!
