this is getting old
dcolpitts
1986 evinrude 140 alarm didnt work on vro failer, all is well however, pulled alarm totally toast. any way to find a repalacement or use a light on the dash to replace this has a two connnector and all the temp and vro sensors have no resistance what would case the the alarm to cook.HELLLPPP
93bronco
Ensign
Re: this is getting old
some have said on this forum that they have used the boat or a car horn so they can hear the alarm go off.<br />ive been thinking about it, due to the fact i can barely hear mine when testing it.<br />-<br />anyone out there know if you have to do something special to hook up a louder alarm?
D
DJ
Guest
okam,<br /><br />Wire a BIG bright LED light in line and put it in the dash.
Xcusme
Okam,<br /><br />I use these in my line of work. Look at this link and find the MA-2 Piezo Sounder. These at one time were made by Moose Industries. This unit produces 2 sounds, 1 beeping , the other a straight tone. There are 2 seperate inputs for 2 sensors. One signal input can be used for a Temp. alarm, the other for VRO failure. Trust me, you won't sleep thru any alarm with this unit. It produces a 100db sound output and uses input voltages from 4 to 24VDC. The unit draws only 25ma of current (25/1000ths of an amp.)<br /> http://www.americominc.net/products/security/sentrolsirens.htm
