Think you've got a bike that will fly?
BoatBuoy
This may have been posted before, but I hadn't seen it.<br /><br />
JB
Re: Think you've got a bike that will fly?
I wonder how long that radial will last without forced air equally to all cylinders.
Dave Abrahamson
THAT is neat!<br />Wonder what it sounds like? The old radials had shorty pipes on each cyl.<br />Gyroscopic effect? <br />Isn't photshopped is it?<br />I would think your arms would get quite warm over the top cylinders.
kenimpzoom
Where are the handlebars???<br /><br />Ken
gonefishie
have you guys seen the jet bike owned by Jay Leno?
20/20
I don't see any frame comming up to the front forks under the engine? I'm with KenImpZoom where are the handlebars?
LubeDude
I can see the handlebars, at least the one for the left hand, but you couldnt carry enough fuel to make it around the block?
timmathis
I would rather have it on a biplane.<br />Tim
Twidget
Dave, arms arent what you should worry about getting warm. :) Like JB said, that is an air cooled engine, with uneven airflow.
sloopy
What does he use as a flywheel? Where is the oil tank? How does he start it?
sloopy
That has to be photoshoped. No way it will work in the state it is in, maybe it is just a work in progress.
sloopy
thekneeslider.com/archives/2006/05/11/radial-engine-motorcycle-2/
sloopy
jrlcycles.com/<br /><br />JOINKERS! I made two post and it looks like 5! I will just spread all the info the post so it looks intentional...
Dave Abrahamson
Originally posted by JB:<br /> I wonder how long that radial will last without forced air equally to all cylinders.
This one better? ;) <br />
<br />Not sure how he keeps the bottom cylinders fron scraping the pavement. Probably a trailer queen :rolleyes:
Dave Abrahamson
Or this old German one....with the radial mounted inside the front wheel. :eek: <br />
<br />C&P The crankshaft was the front axle, which remained stationary while the cylinders rotated with the wheel, an architecture called the Monosoupape design. A hand-controlled butterfly valve was located in the hollow crankshaft to regulate throttle. Power output was a meagre 14 bhp (10 kW) but was applied directly to the wheel.
