backyardangler
- Feb 18, 2009
- 24
I've been fixing up a '95 40 Force. I've changed the impeller and it seems to be working. The lower unit cooling channels were full of dirt dauber nests. I have water coming out of the upper hole, but it's not the stream it should be, its a fine spray. It seems restricted. When I had the lower unit off I put a garden hose on the orafice and ran water up the cooling water tube, I never got a good stream and I don't with the boat running. The impeller is new and I have a good stream coming out of a lower hole.
Yesterday I ran the boat for the first time, it ran fine but the Cylinder head temp gauge was innop. Coupled with the lack of cooling stream I opted to just shut it down for the day since I could not tell if it was overheating.
I read here that you can run weed whacker line up the hole. Is there anything I can dammage by doing this? Can you actually get whacker line up into the head. It just seems like I'm missing a dauber somewhere. This boat was stored outside for 5 years. Any advice would sure be appreciated.
