These cylinder heads trash?
BigB9000
they came of the 77 115hp I bought for parts. (It threw a rod)
I was thinking of ebay the stuff to get my $20 back, but I dont know if these are even worth listing:
keep em, or trash them? or just list the one side?
and are they steel or aluminum?
71Windsor
Re: These cylinder heads trash?
the easiest way to check for aluminum is to go grab a regular old magnet and try to stick it to it. aluminum is not magnetic.
ezeke
They are aluminum. You could use that if you smooth it out. You would be better off with a good one. Get the part number off the casting [see below].
