thermostat
surfsup53
I am new to boating, I have a 1975 Johnson 115hp the water flow is weak. I had a freind tell be to check if the thermostat to see if it was stuck. I bought a selok manual for motor but it does say any thing about a thermostat . Can anyone tell me where to locate the thermostat on the motor.
Dhadley
Re: thermostat
How do you know its weak? How much water pressure do you have? If this motor is new to you and / or you are unsure of the last cooling system service, now is the time to do it. A new pump kit (complete), head agskets, deflectors and thermostats is a good idea.<br /><br />The T-stat is located at the rear of the adaptor housing and has a hose from each head running to it.<br /><br />Good luck!
