CaptainPuget
- Sep 29, 2002
- 137
Im having problems getting the right thermostat parts for a 1987 Johnson 70hp, or at least getting them to fit right. I notice that iboats and many other internet parts places do not carry parts for this year model. My local OMC shop sells me P/N 434137 ($29.50!) which doesnt look much like my original T-stat but they tell me it supersedes the old one and will work fine. I also get the spring and the rubber seal that goes under the T-stat and the stainless steel retainer ring that fits in the powerhead and holds the rubber seal in place. In trying to re-assemble everything I notice that the retainer ring is too big to fit all the way into its place in the powerhead. I try the old one and I see that it is the same. It only goes in about halfway. I know this isnt right but thats the way it came apart so I put it back together that way and try it out. <br /><br />No good, still cold at idle. I take it apart and the rubber seal has pushed forward preventing a good seal with the plastic T-stat housing. So I go back to the OMC shop (60 mile round trip) and we double check all the parts and they match what the book calls out. No one knows of any bulletins on the issue and they dont have any ideas. <br /><br />Im out of ideas. This engine only had about 10 hours on it when I bought it several months ago so Im pretty sure that I removed the original T-stat and it came from the factory with the seal not properly seated. The problem appears to be a design defect or maybe the powerhead was machined incorrectly. <br /><br />Has anyone encountered this problem before or have any suggestions for a solution?
