Last night when I got home I got a call from a guy with a 200 that was overheating. The shop he was taking it to couldn't resolve it and had changed everything. He asked if I had time to take a look at it.
He brought it by and we put it on the hose. The head temps climbed up to 160 on both sides (infrafred thermometer) and the tell tale was weak and spitting. Good water flow out the hub so the pump was working.
For lack of any other suspicions I pulled the thermostats and after looking at them for a few minutes I realized that the rubber grommet gaskets were upside down with the lip side pointed into the head instead of into the fitting. I flipped them both over and reinstalled them and WA LA.. temp head stabilized at 140 and the tell tale was strong.
For the life of me I couldn't see what was being blocked. Obviously something is. If you happen to have this problem this might be worth checking.
