115HP. Thanks ever so much! Strange there is no mention of it in manual?Which motor are you asking about? 115 hp or a 3 - 27 hp? The 115 hp has a thermostat. It's on cylinder head/cover top left.
Unfortunately it does not have any temp gauge. It's a 1990 Sea Pro that I just bought recentlyDoes your boat have a working temperature gauge?
Just keep in mind, these motors are more likely to have the warning module go bad than the thermostat. Have you checked the water impeller? That is also more likely.Unfortunately it does not have any temp gauge. It's a 1990 Sea Pro that I just bought recently
To check/replace the impellor you need to unbolt and remove the lower unit. The process should be in the manual. It is in the Mercury shop manual. There are probably you-tubes that show you how.Thank you so much Dave1027. You have been a great help! The warning horn is not on all the time...........just intermittently. Do I need to take it apart to check the impeller?
