Thermostat For Alpha 1
bmetros
I have a 1992 5.7L Mercruiser and have noticed that the temp guage is climbing to 200+ when traveling at higher speeds (20 knots and above). If I drop my speed to 10-15 knots the temp goes down to normal (180). I want to change the Thermostat but the book states I have to drain the block and so on. This is above my level of DIY. Can't I just remove the 2 bolts, pop out the old and insert the new?
Haut Medoc
Re: Thermostat For Alpha 1
All ya gotta do is loosen the two petcocks, (one on each side) down below, to drain the block....
You will need to find them to do winterization anyway....
*note....That is not all you need to do for winterization.....
I'd suspect the raw water impeller in the drive before the tstat, though....;)
Ayuh,.......... Same Here...............
DHPMARINE
I actually would be thinking exhaust elbos and manifolds,but yes I'd start with the pump impeller,to be sure it was good.
DHP
