Thermostat 7.5 Rude
sterling66
Want to check , is this something to check after<br />engine got a little hot?Where is it ,is this hard to change ? Went to dealer today order everything to fix impeller.Order man. but takes few days to get here . Thanks
rickdb1boat
Re: Thermostat 7.5 Rude
sterling66
One more thing could someone give me the torque specs, for water impeller and thermostat housing, as i think ill be doing both? :D
sterling66
Great!!!!! took off water pump housing no thermostat?Now what???????(**##$) Thanks really pissed now gGGGGGGGGGGHHHHHHHHHH.
rickdb1boat
Get New T-Stat and install. Just snug the bolts up! Lower unit bolts Torqued to 60-80 "IN/LB, Not FT/LB!
sterling66
Thanks Ricky you sure help lots ,hope oneday i can return fav. Sterling .P.S Email the :confused: guy that sold it to me and gave him my 2 bits.!!!!!!!!
sterling66
What do you guys think about retorquing head and exhaust bolts,should i check?Manual request this ,how hot the engine really got dont know.
plywoody
Did the engine seize, or burn paint on the block, or anything like that? If not, chances are you don't have a huge problem<br />BTW, a missing thermostat is not a huge deal. Engine will just run cooler than design, and while it might make it run a bit rough at idle, it won't hurt anything. Removing it is the standard quick fix for a faulty thermostat when a new one is not readily available.<br /><br />Retorqueing (sp?) the head bolts certainly won't hurt anything. Maybe Rick has the specs, but it is in IN/LBS and not foot/lbs and just be careful not to overtighten them--it is pretty easy to strip the threads in the aluminum block.<br /><br />John
