Hey guys- I was hoping someone could set me straight and explain to me what the term "Decarb" means. If it means spraying a can of that OMC Engine Tuner spray in the carbs, then Im good. If not, then Im clueless.
Also, I am a new owner to a 1990 200hp Johnson and was curious what the manufacture's WOT readings are. I run 55 mph at about 5400-5500 rpm with a 14 1/4 in, 23 deg prop. Does that sound right?
Thanks
Thanks
