I'm relatively new to boating, about 4 yrs. I did quite a bit of repair on car engines and other machinery. Now I'm in the process of rebuilding or replacing my frozen Mercruiser Alpha drive. I'm amazed at the design! <br />Anyhow my question is why isnt the shifting(forward,nuetral reverse) in the dry part of the boat? Also why is the water pump buried in the middle of the drive with dozens of seals to prevent water from getting to places where it will screw things up. I would think a self priming pump attached to the engine could pull in water from a hose. If the only external part was the gimbal steering, U Joints and a prop, the drives would be a heck of alot more reliable. Not to mention if the bellows for all these holes in the transom leak, the boat sinks! Maybe I should get an Inboard! Anyone hear about these type drives. Just curious-http://www.dbdmarine.com/dbdmarine.htm
