THE RIGHT WAY TO BREAK-IN A NEW OUTBOARD
cpahl_99
I HAVE BEEN TOLD BY MY DEALER THAT IS TAKES TEN HOURS TO BREAK A MOTOR IN, I ALSO READ IN A MANUAL FOR A 1984 9.8 MERC THAT IT TAKES ONLY ONE HOUR.<br /><br />ALSO YOU ARE NOT SUPPOSE TO LET IS IDLE AND YOU ARE SUPPOSED TO VARY THE RPMS, AND NOT DO FULL THROTTLE AND RUN DOUBLE THE REGULAR OIL RATIO. THEN AFTER THE TEN HOURS IS UP I HAVE TO TAKE IT BACK TO THE DEALER TO CHANGE THE LOWER UNIT OIL.
walleyehed
Re: THE RIGHT WAY TO BREAK-IN A NEW OUTBOARD
1984 Merc isn't a "new motor"....If you've got a new one, follow the manual or the dealer's advice.<br />Put it on him if something happens that way.
Clams Canino
10-20 gallons at double oil - varying RPM's and avoiding WOT till the end. Break it in in the morning - ski in the afternoon is my motto.<br /><br />-W
