Hello Friends,
As you saw in my previous post, my 1979 Johnson 85 is having 1 piston with low compression (90 - 120 -120 - 120) but is still running Strong ! I have read a many site about it's not worth rebuilding it because of cost etc.. some even approached a 2500-4000$ estimate cost to fully rebuild the motor.
My question is, as a DIYer, what can be the real, not exagerting cost of PARTLY- rebuilding such engine, especially for my personnal case. This is what I came with by looking at the parts diagram. Of course, I will be doing this myself
To my understanding, these parts has to be changed and cannot be reused:
1- 4 pistons with ring and wristpin and all clips (wiseco are $56 per kit per piston)
2- 4x rebore if necessary (not sure yet it will be necessary, maybe just rehone)
3- 4x wrist pin bearing
4- All gasket exposed while opening up the engine
5- few oring here and there and seals....
These parts, to my understanding, can be reused:
1- 4 Connecting rods
2- crankcase head bearing assemble
3- Nuts, bolts and washer that are not damaged
4- Crank ! (should be good)
Considering I have done all this so far during the last months:
1- Carbs rebuild
2- new starter
3- New CD2
4- New coils pack
5- New fuel pump
6- New plugs
7- New thermostat
8- New waterpump
9- new stator power invertor (can't remember the real name)
What do you guys think. Am I missing something Really big that can overcome my little project ? Any help would be greatly appreciated !
Thanks
Bo
1- Carbs rebuild
2- new starter
3- New CD2
4- New coils pack
5- New fuel pump
6- New plugs
7- New thermostat
8- New waterpump
Thanks
Bo
