Thanks to the help I got on this board I installed the fuel water separator and there were no leaks,drips or errors. I finally got the boat out yesterday and it ran strong. The only thing that concerns me is the water pressure reading. I have a 1980 85hp Rude that only shows 10-12 psi WOT. I did a search here and it seems that a V-4's low pressure is common. The impeller hasn't been changed yet and when I do will my pressure go up. My mechanic says the pressure should be at least 15 psi.
