I have an 80hp. Mercury 800 with Thumderbolt igintion, 1970 Ser#2881497... and of course like half the other posts, no spark. It ran fine. I stopped it, it would not start again, it had intermittent spark, sounded like it wanted to run, but wouldn't take. I replaced the external harness with a used one and it ran for a brief time, now have no spark at all.<br /><br />I'm not sure if this is the way it is "supposed to be done", but it makes sense to me.<br /><br />Can someone tell me what path the spark takes... I want to systmatically check each point where a problem could occur. I've replaced the plugs, and wires, I don't know what the points should even look like, so I'll probably change them and the Distributor cap(still cheap) . What should I check next in line? and in what order is the most likely problem?<br /><br />My other (probably stupid ) question is, I bought the boat used, he had a new battery in the boat, and I used it for two years..... now I read on a troubleshooting sight that maintenance free batteries can "over charge" and ruin the CD.... what is the CD, and can it be replaced? <br /><br />Thanks
