Re: The engine smokes a lot
Could you have a 454 or 350 and not a 354 ? Also you havn't said what type of drive you have I,R,MR, Alpha or Bravo or even TR.<br />IF you have a Bravo or TR drive the w/p is located on the front of the engine and is driven by a belt off the crank.<br />If you have a Alpha(I,R,MR) drive the pump is located between the upper and lower parts of the drive so the drive must come of to service it.<br />There is one more thing does the engine have closed cooling , because in some cases with a Alpha drive a belt driven w/p is installed on the engine to provide extra water flow.<br />Let us know what you find.
