sms986
- Sep 18, 2017
- 334
So, I'll start off with saying this is an 89 Mercruiser 305 with a 350 short block. I've got 3 issues to tackle. I chose to put them all in the same post so that I didn't clutter up the form with a bunch of posts all at once. First, I believe I have a vapor lock issue. The boat starts fine cold, but when warm it doesn't want to start. It'll take at most 10 seconds to fire, then another 5 of fiddling with the throttle to get it to idle. It isn't over heating, water temp is 120 degrees. When warm it also surges at idle. Goes up to about 1000 rpms then almost dies, then repeats. Possible fixes? I think I'm going to go with an aluminum spacer and insulation on the fuel line.
Second, the boat stalls when shifting from reverse only. I've scoured the forums for an answer since I thought it was fairly common. Found nothing. It shifts to and from forward fine, and into reverse fine. When shifting from reverse it completely dies, no matter how fast I shift. Lower cable was just replaced.
last and most important, I still have this mystery clunk coming from the rear of the boat when under load. I drive it at 3/4-full throttle for 20 minutes no problem. On the way back, I was at no wake speed through the channel and acclelerated to full as soon as I got out. Got to about 3/4 and heard a loud clunk that shook the boat. Dropped it down to half and went back to the dock. Anything above 1/2 and the clunk comes back. Ujoints are good, I am positive. Gimbal bearing was replaced. Trim was all the way down. This one has me puzzled. I can't find anything in any forums that solves this, nor can I find a video of a similar sound on the tube. Any help appreciated. Thanks!
