The Carb problem with the 84 140
gonefishn
Thank you for the info, it seems that there are 3 circuits to these carbs, Low, Med, High rpm's the motor is a 83 V-4 140. The low end circuit is the problem so I've been told so I need to find a carb for a 1983 V-4 140 Crossflow preferably new, so if anyone could point me in the correct direction that would be great... Thank you in advance
Dhadley
Re: The Carb problem with the 84 140
The carbs feed across so if your other post is correct when you said the two "right" side cylinders shut off you need two carbs. Are you sure it's suddenly both carbs bad when they were ok before? It's worth thinking about before you spend that kind of money. Re-read your other post.
